I'm getting nothing from the tachometer. Needle does not move at all when I turn the key on, I see all of my guages move except the tach. (stays at 6 o'clock postion)
So far I've tried:
1. Rotating the switch on back of tach around - 4cyl, 6cyl, 8cyl thinking maybe it had a bad contact. No change
2. Replaced Tach with brand new Faria (Same one). No Change
3. Put a circuit test light on Pos/Neg on back of tach and does light up indicating power. Appears to be daisy chained to other guages which are working.
4. Put a circuit test light on the engine signal wire connection next to the distrubutor coil wire (Grey and a Green wire go into this connector). Lights up indicating power/signal
When I turn the ignition key to the on position and see the guages move, should the Tach move to the 0 position indicating power? Any thoughts?
So far I've tried:
