Anyone had any issues with a PCM 343 Engine crank but won't start problem. Had a mechanic come to the dock and take a look. The computer isn't throwing any codes, he tested Fuel Pressure, Spark and all fuses and relays with no luck. Any thoughts? Thanks in advance.
The first thing that comes to mind in that scenario is that the lanyard may be disconnected.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
When's the last time the distributor cap and rotor have been replaced? The EX343s tend to get hairline cracks in the distributor caps. If they haven't been replaced, then I'd try that first since it's cheap and should be done anyway. That distributor also has a tendency for the tabs for the distributor cap screws to break off. Dorman makes a repair plate for that issue. You can find it amazon.Last edited by jpwhit; 07-18-2023, 06:32 AM.
Distributor Cap & Rotor replaced last summer. Mechanic tested with a spare of each when he came to the dock.
Spray a couple of shots of starter fluid in the intake. If it fires and runs for a second, then it's a fuel issue. Could be water in the fuel for example. Or could be issues with the injectors not operating. If it doesn't fire with starter fluid, then it's likely an ignition issue.
