Broken NSS screws
  • zmnypit
    • Sep 2020
    • 158
    • Alabama
    • 2017 G23
    Broken NSS screws
    Replacing a faulty NSS actuator on a 17 G23 and a couple of the stainless wood screws just snapped at the head when removing. Whats the easiest way of removing them to so I can replace?
  • kylant
    • May 2010
    • 560
    • Lake Tahoe
    vise grips
    • zmnypit
      • Sep 2020
      • 158
      • Alabama
      • 2017 G23
      Originally posted by kylant View Post
      vise grips
      I was going to see if I could grab them from the inside with vise grips. They are flush with the fiberglass on the outside so no way to grab them
      • Scooter G
        • Jan 2022
        • 1497
        • On a Lake in Idaho
        • 2022 G23 ZZ8
        You'll have to use an easy out or screw extractor, run an Amazon search. Watch the reviews, there is some junk out there.
        Chances are you'll use the kit down the road. I have 1/2 a tool box drawer filled with sheesh to get broken screws & bolts out.
        Good luck, sorry for the headache, that's a bummer.
        • srock
          • Oct 2008
          • 1136
          Easy out on stainless...is it that easy. Are they big enough.
          • zmnypit
            • Sep 2020
            • 158
            • Alabama
            • 2017 G23
            It wasnt lol. Smoked every bit I tried. Ended up leaving them and just put extra 4200 around the area
            • Scooter G
              • Jan 2022
              • 1497
              • 2022 G23 ZZ8
              Sorry about the drill bits, stainless is a bugger.
              Sounds like you found a work around, maybe.
              Good article for future reference...
              https://www.sailmagazine.com/diy/kno...tainless-steel
              • jpwhit
                • Aug 2016
                • 673
                • Cary, NC
                The right way to fix this, is to use a very small diamond hole saw and drill out around the SS screws. Then install SS threaded inserts into the hull.
                • Scooter G
                  • Jan 2022
                  • 1497
                  • 2022 G23 ZZ8
                  Agreed jpwhit, and probably a major short cut to making enough room in the gel (dremel) to hopefully get a grip on the screw, and then coming back in with the gel repair.
