I have been a long time lurker on this forum but this is my first time posting so hopefully I have this in the right place. I have searched all over this forum and the internet trying to find someone who is experiencing similar issue to me. We have a 2013 PCM ZR409 in our SAN 230 and it currently has 780 hours on it. The engine runs great but lately it has been consuming a bit of oil. I would say a quart every 20-25 hours or so. It also varies with RPM and load. We have always changed the oil every 50 hours using Mobil1 5w-30 synthetic. I also did a full coolant drain and refill last season. Boat always holds proper temp. I changed spark plugs at the end of last season and nothing was out of the ordinary. I am not leaking oil anywhere and the boat isn't throwing any blue smoke and really any smoke at all (we don't have surf pipe) when running.
I have read on auto forums that a lot of the 6.0's came with a poorly designed LH valve cover which houses the PCV port. Changing the valve cover to the updated design seems to have solved a lot of the oil consumption issues. Should I pull the valve cover to verify if it is the updated design? Or should I do some diagnostic testing first (compression test, leak-down, etc.)? I have been hesitant to pull the cover because I would have to remove the exhaust manifold on that side. I pulled the PCV hose that connects the valve cover to the intake manifold last season and it was quite oily. I cleaned it the best I could and reinstalled but just looking for some direction here from someone who knows these engines well or has experienced similar symptoms.
