Excalibur spark plugs
  • Fonseca
    • Apr 2006
    • 35
    • Portugal - Castelo de Bode
    Hi everybody.
    Another question from Portugal:
    What do you think about conventional spark plugs and platinum ones?
    In the boat manual they recommends AcDelco conventional spark plugs, costing 2$ each. The platinum is ten times more expensive.
    Do we get any advantage in using it?
  • TRBenj
    • 1683
    • NWCT
    RE: Excalibur spark plugs
    Platinum plugs can last a lot longer than conventional plugs- which is great for longer service intervals. However, performance will be just as good, if not better, with the standard plugs- they just need to be replaced sooner.
    1990 Ski Nautique
    NWCT
    • nautielove
      • Sep 2006
      • 3
      what is the interval between plug changes ?
      • nms1991
        • 477
        On the excalibur engine the platinum plugs are already installed by the factory. Pcm said you should not have to replace plugs on this engine unless there is a problem like leaking injector or oil fouling or a ignition problem.
        • aaron
          • Sep 2026
          • 114
          • Malaysia
          I have had 600 hrs on the engine with the original plugs and the Excalibur still doesnt miss a beat, apart from some fuel pump and relay issues.
