Linc system black screen
  • 2016SPORTNAUTIQUE200
    • Aug 2016
    • 59
    • OKLAHOMA
    • 2016 SPORT NAUTIQUE 200
    Was on rhe watee today and Linc screen went black. Everything still works. Ideas? Pic is actually from today before it went black.
  • vision
    • 530
    • NC
    • 2013 G23
    I would inspect the main power line and or inline post fuse coming off the battery selector switch. Power to the motor and linc computer split right after the selector. That was the culprit on my boat.
      • Aug 2016
      • 59
      • OKLAHOMA
      So after disconnecting battery and rebooting everything, somehow when I turned the navigation lights on the keypad the screen came on. Turn nav lights off and screen goes black again. Had no idea keypad could affect the linc screen. Anyway, shut everything down again while nav lights were on, restarted and everything works normal again. Go figure.
      • amaaraba
        • Aug 2020
        • 26
        • Lake Geneva, Alexandria MN
        • Minnesota
        • 2012 200vTE
        Not sure if this matters but it looks like your screen is setup for a different model than a 200v since it's showing the NSS settings. I know you can change the display in the dealer settings menu.
          • Aug 2016
          • 59
          • OKLAHOMA
          update: dealer thinks it is a short with the keypad. When i turn nav lights off on keypad, screen goes black. Turn nav lights back on, screen comes back on.
          • charlesml3
            • Jan 2008
            • 2487
            • Lake Gaston, NC
            • 2022 G23
            Are you SURE the brightness wasn't turned all the way down? This is exactly what will happen if you come in late at night with the NAV lights on and you turn the brightness all the way down so the panel isn't so bright. The next day, you come out and the screen is black.
            -Charles
              • Aug 2016
              • 59
              • OKLAHOMA
              Brightness is all the way up. Last time dealer had it they programmed Linc to a 21 model so reprogrammed back to 2016 Sport and it corrected surf system which it does not have. I passed on fixing since they want $600 and its not affecting anything currently. Just annoying.
              Neutral to rev engine not working either. They want $900 to fix this as you have to buy entire throttle assembly to fix. Passed on it. Dont need neutral rev that bad.
              • SilentSeven
                • Feb 2014
                • 2241
                • Bellevue WA
                • 2004 Nautique 206
                ...I think this is why I'm never getting a newer boat. These aging e-systems are brutal.
                Bellevue WA
                • bturner
                  • Jun 2019
                  • 1790
                  • MI
                  • 2016 200 Sport Nautique
                  Mine is doing the same on the neutral rev intermittently. I keep thinking about doing it and may still. ~$600 for the part and I'm told it's fairly easy to do which I would have to think it is if your dealer is only charging you ~$200 to install......
                  https://nautiqueparts.com/throttle-b...and-sport-200/
