I have a 2022 Nautique 200 with a 6 liter and winterizing it. I unhooked the drain lines and blow the heater core out, that seems to simple. Is there anything else I should do
Stabilize the fuel, store battery on a maintainer.
You probably didn't have to drain the heater core. Newer boats have anti-freeze running through the heater. Assuming that's the case with yours, be sure to top off your coolant in the spring since you removed a good amount draining the heater.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Are these completely close system cooled or do you need to prortect things like exhaust manifolds?
Did my 200, with the standard ZR4, yesterday. Have a nice cut on my finger from pulling a stubborn hose. I did not disconnect at the raw water pump outlet since the same hose was pulled from the oil cooler. Wish I had the new system with the quick disconnects.
