Service costs in Georgia
  • MN Ryan
    • Aug 2020
    • 1395
    • Maple Grove, MN
    • 2007 SV-211 TE
    Alright, here's what is invoiced for winterization where I have it done (yes, I realize that things like charging batteries, adding fuel stabilizer, etc are no brainers, but they're part of the process):
    • Add fuel stabilizer
    • Charge batteries
    • Winterize ballast system
    • Run engine up to operating temp
    • Service flame arrester (?)
    • Change tranny fluid
    • Check v-drive fluid
    • Change oil and filter
    • Run and check for leaks
    • Drain water from engine/system
    • Fog cylinders/valves
    • Flush engine system with freeze protectant
    • Winterize heater
    • Clean tranny cooler and strainer
    • Recheck all drains and hoses
    • Coat engine and pulleys with light oil
    • Disconnect battery cables
    About $120 for parts, $50 for "shop supplies", and $440 for labor. Add on $60 for an impeller kit and $280 for labor on the impeller.
