2021 GS22 Engine Failure
  • Devo77
    • Mar 2019
    • 39
    • Lake Keowee, SC
    • 2021 GS22
    Was out on our lake on Tuesday and stopped to swim. When trying to start the boat we got several warnings regarding low oil pressure. Despite having oil we could not get rid of the message. I was able to get to a landing close by. I called our dealer and was fortunate that they sent a mechanic with trailer to where we were in 40 minutes. After a fairly quick diagnosis he said our engine would need to be replaced! He said it was a common problem for the ZR4 engine for model years 2020 and 2021. Has anyone else had this problem? We only had 110 hours on the boat! I'm sure it will be covered under warranty but assume our summer is over - what are our chances of getting a loaner boat from dealer/nautique?
  • charlesml3
    • Jan 2008
    • 2487
    • Lake Gaston, NC
    • 2022 G23
    It is not a "common problem with the ZR4 engine." That engine has been in Nautiques for years now, the vast majority of them trouble-free. You had what is most likely an oil pump failure. Certainly not common, but it can happen.
    • kylant
      • May 2010
      • 561
      • Lake Tahoe
      was there any indication of a problem before you shut it down? was there oil pressure?
      if there was no problem before you shut it down, i would bet it is a sensor (oil pressure).
      sure it could be a bad pump and a catastrophic failure, but i think that is pretty quick to jump straight to an engine replacement
      • Devo77
        • Mar 2019
        • 39
        • Lake Keowee, SC
        • 2021 GS22
        If it is a defect and replaced under warranty is it reasonable to ask for a loaner boat given we still have half the summer left? What are the chances of getting one?
        • ScooterMcgavin
          • 1551
          • 2014 SAN 210 TE
          It’s reasonable to ask for sure, But this will depend on several things like your dealer and availability. They definitely should and wouldn’t hurt to ask.
          1989 Sport Nautique
          • Devo77
            • Mar 2019
            • 39
            • Lake Keowee, SC
            • 2021 GS22
            So they replaced the engine block. Apparently have to now go through the 20 hr breaking period again. Does this mean boat hours and warranty should reset?
            • mikenbike211
              • Sep 2016
              • 449
              • New York
              • 2021 G21 2019 GS22 2017 GS20 2008 SV211 1990 Sport Nautique
              i dont think so
