Hey guys took the boat out first time this season after running it up on land on the garden hose. Forgot to replace the hose for the raw water pump and burnt out my impeller / overheat ( engine hot code ) the temp gauge was up to the top before I realized what was going on. I took the impeller out and cleaned out the hoses and pump as best I could, also noticed a small nick in the pump housing that must have always been there? See in pics. Is there anything I should be worried about? I will replace the impeller / oil, the oil filter is new should I just replace it when doing the oil or leave it? I also saw to check at the thermostat for pieces of the impeller getting stuck there so I will check that as well. Do you think pump housing needs to be replaced? I would say it seems to have been running fine like that since Ive had the boat the last 4 years. Moral of the story always use your checklist! Check for cooling water flow when first running and always keep an eye on gauges. Thanks!
