2006 SANTE 220. When I long press the button on the panel to reverse flow the pumps, it begins to blink, but the pump doesnt not run in reverse. It will fill as it should, but will not empty. It doesnt run at at all in empty mode (flashing). I pulled the connector and ran it to another set of wires to a different ballast pump and it worked, so I know the pump works. The light on the dash blinks and all the other functions of the push button panel work.
Where does the reversing of polarity take place? is there a switch somewhere in the boat or does it take place inside the panel? To sum up my questions, do I replace the panel or start with a cheaper switch? Any advice is appreciated. Thanks in advance.
