2016 SAN 210 Ballast Issue
  • BMo
    • May 2020
    • 7
    • Michigan
    • 2016 Sport Nautique 200V
    Hi,
    I have a '16 SAN 210 with pro ballast.
    Last season, LINC was reading 7/8 full for ballast tanks but water emptying into lake thru over flow. In fall, Dealer said likely need to replace sensors but $$$$. Instead they reset the timers thinking they may solve (also had impellers in ballast replaced). This season, LINC showing ballast at 1/2 or 5/8 full when sitting and first start boat. Put on hoist hit drain and there's no water to drain. Pumps work great...filled/drained, etc for surfing. When floating / swimming manually shut off valves just in case but LINC still read 1/2 or 5/8 full on way in. Again, put on hoist and no water to drain.
    Anything I can do manually / within LINC to reset timers? I have a dealer code. Or is truly ballast sensors and will need to replace?
    Any help appreciated as prefer not to pull boat out and have down time this summer.
    Thanks!
  • Scooter G
    • Jan 2022
    • 1509
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    BMo, you are probably looking at new sensors here, good luck bud...
    https://www.planetnautique.com/vb5/f...a-new-approach
    https://www.planetnautique.com/vb5/f...essure-sensors
    https://www.planetnautique.com/vb5/f...ast-tank-issue
    https://www.planetnautique.com/vb5/f...or-replacement
