1984 Nautique 2001 Prop Recommendation
Owned the boat for 3 years. Run it in Lake Tahoe (Elevation 6,250ft). Pulling a skier out of the hole has always been tough. My neighbor said the boat has the wrong prop. It is a 4 blade with “208 13X 12.5V RH 1” the best I can read it . Trans - Velvet Drive 1:1. Any help with a recommendation and supplier would be greatly appreciated
Tags: None
You could check over on https://www.correctcraftfan.com as there’s a lot more guys running the ‘80s vintage boats and several running them at altitude.
They are going to need some info on your boat like the Hp, RR or LH rotation, transmission 1:1 or 1.23:1 and what you do want to do with it as in ski or wake board with or without extra weight.
They’ll get you dialed in, good luck.
The ACME 540 is considered the general use prop and the 542 the wake/high altitude prop for an 83-88 Ski Nautique running a RH 351 and 1:1 transmission.
