I ran into an issue this past weekend on my 2016 G21. The starboard ballast tank seems to be reading 0% in blue on the Linc system, but 0%. Yet the overhead display says there's still 946lbs in the tank. When I go to fill up, it will read 90% in like a minute while the other tanks are at 10% or less. When try to drain the tank manually no water comes out, but the boat does seem to lean towards the starboard side like there is water in it. Assume it may be the pressure sensor that has gone bad, but before I start taking the boat apart wanted to see if anyone had any experiences here.
Thanks much in advance
