Crank Position Sensor Aftermarket
  • actman
    • Dec 2009
    • 166
    • Ontario Canada
    • SN 200 OB many 196's
    Was wondering if anyone has tried an aftermarket Crank Position Sensor for the Excalibur 5.7L . The OEM in Canada cost $300 at my dealer. I have seen aftermarket from $22 and up . They look the same.
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    it going to be same part if you can figure out the cross reference...
    • actman
      • Dec 2009
      • 166
      • Ontario Canada
      someone mentioned they used one from an older Chevy suburban for referance
      • Hexa73
        • Aug 2015
        • 42
        • France, Savoie
        • CORRECT CRAFT SANTE 230 08'
        For engine parts, I buy them on Rockauto.
        I dont know if it corresponds to your engine but by finding the GM reference you will quickly find what you need :
        https://www.rockauto.com/en/catalog/...on+sensor,7196
        • SilentSeven
          • Feb 2014
          • 2241
          • Bellevue WA
          • 2004 Nautique 206
          I've had good luck pulling the part in question and taking it to the parts counter at the local autoparts store.
          Frequently there are mfg numbers on the part they can use to locate the automotive cross-reference and get it ordered or...if they have it...do a side by side comparison on the spot.
          As you noted, much of the sensor gear is standard automotive stuff and it's much cheaper than buying from the dealer...just need to figure out what it is.
          Bellevue WA
