Battery selector switch failure and replacement 2014 210
  • ScooterMcgavin
    • 1551
    • 2014 SAN 210 TE
    I had a battery selector switch completely come apart on me today. I have read on here about this happening to other people in the past so I was prepared. I had noticed the last time I took the boat out when I turned the battery selector switch on it didn’t have the normal stopping points at the numbers and felt easier to turn than normal , Almost like it was same loose tension feeling all the way around the dial. It didn’t stop at the numbers, I had to stop the dial at the number I wanted, I thought then that’s not right.
    Boat ran fine that day but when I got home I ordered the new switch.
    Well I hadn’t put the switch on yet and today when I went to start boat I had no power to the Helm. I thought immediately it was the switch so I pulled the panel under dash off and looked at the back of the switch and could tell right away it was separated.
    Click image for larger version  Name:	20B5D3CF-9A6D-47D8-A94B-86EA2F4F811E.jpeg Views:	29 Size:	73.0 KB ID:	643390
    So luckily already had the switch and so first thing I did was unhook the battery’s.
    Click image for larger version  Name:	FF82B268-B1DB-4AC8-9599-07CD172A3134.jpeg Views:	27 Size:	106.4 KB ID:	643391
    Then I took a 9 millimeter 1/4” socket with extension on the backside of switch and a Phillips screwdriver on the front 4 screws that hold the switch in place.
    Click image for larger version  Name:	CAFEA5DB-F7F6-48DD-B9B3-58BE42744769.jpeg Views:	27 Size:	84.6 KB ID:	643392
    Removed the front part of the switch and then worked on the back part. I used a socket and removed the bolts that held the wires onto the switch.
    Click image for larger version  Name:	85027914-74CE-423B-ADDC-09239BCFC150.jpeg Views:	27 Size:	64.3 KB ID:	643394
    Click image for larger version  Name:	19962DA3-EE4A-4149-BF0F-DFB15F58BD6F.jpeg Views:	27 Size:	92.8 KB ID:	643396
    Click image for larger version  Name:	D792239E-B5EA-49A2-901C-5A211EE74CA6.jpeg Views:	27 Size:	82.1 KB ID:	643398
    Installation is just as simple, Seems like they revised the part, The new one is a perfect fit, Just slightly different, The back of the switch where the 4 screws come through have a recessed area for the nuts and you can’t use the washers that came from factory and you don’t need them with the new design.
    Click image for larger version  Name:	0D56B1E8-3DD0-47B0-89BF-AD7F99ABA740.jpeg Views:	27 Size:	35.8 KB ID:	643393 Click image for larger version  Name:	F114F9A9-A574-41BD-AAA5-A4D4EC687282.jpeg Views:	28 Size:	94.2 KB ID:	643397
    Hooked batteries back up and everything at helm powered up as normal. Saved the weekend!
    So if your Battery Selector switch feels way easier to turn than it used to, it’s a good sign your switch could be going bad.
    1989 Sport Nautique
  • shag
    • 2217
    Nice write up!
    • bturner
      • Jun 2019
      • 1782
      • MI
      • 2016 200 Sport Nautique
      I've ran into this twice, one on a boat I owned and another on a friends boat.
      Very good write up. I'm sure this will be useful to others.
      • SatherG230
        • May 2018
        • 92
        • MN
        • 2012 SANTE 230 w/ NSS
        I had a switch come apart on me on July 4th, only I did not have a spare and it left me on the FAR end of the lake, 15 miles from where we were staying. Similar deal - the switch felt looser the prior time or two and I had almost ordered a replacement that week. The bad news was that I did not have a spare. The good news is that we have friends that live on the lake and a quick call and a short wait and I had some tools to use.
        If your switch fails, you can save the day by stacking one battery cable on top of the OUTPUT cable (the left lug as you look at the back of the switch) which bypasses the switch. I would then disconnect the battery cable each night, but ran fine for the rest of the trip! When I did replace my switch, I also added a Blue Sea ACR right beside it on the back side of the panel. Now I don't have to worry about moving the switch between batteries as much and always have charged batteries.
        The older switches simply had screws holding the front to the back. Mine broke just beyond the tip of the screws. The newer switches snap together and are through-bolted so they should not come apart
        • mcosub
          • Aug 2016
          • 235
          • Orlando
          • 2020 GS22 2017 SANTE 210
          happened to me on my 2017 210 sante..............luckily I was at my dock and took a quick run down to the dealer for an under warranty replacement. 30 min after I got back and I was back up and running.
          • wakekat15
            • May 2018
            • 4
            • Spicewood, TX
            • 2016 SAN G23
            Thanks for the tutorial, Scooter!! Waiting on my new one to arrive, so this is a great help!
            • ArtLindsay
              • Aug 2022
              • 1
              • Richmond, VA
              • Super Air Nautique TE 230
              Oh man...I suspect that this is happening to me ATM (2011 SANTE 230). I had no power to the key pad. Switch feels loose. Next daylight, I'm gonna inspect. New switch already ordered JIC.
              • uwhusky
                • Aug 2006
                • 320
                • Salt Lake City
                • 2015 SANTE 210 w/PCM 450hp engine
                ScooterMcgavin thanks for the great write up.
                I think this is happening to me at the moment. My switch is smoothly moving from OFF to 1, 2 or 1&2 with no clicking to the proper points. Boat won't power up. Luckily it's in my driveway but I was hoping to take it out tomorrow.
                I have my doubts as to whether or not I can get a replacement in the morning but will try. If I can't, is there a hack to make it work for the day or is it not worth it? Or too risky?
                Does anyone have a link to order the part?
                Do I need to disconnect all batteries cables from the battery when I do replace the switch?
                • ScooterMcgavin
                  • 1551
                  • 2014 SAN 210 TE
                  Yes it does sound like a failing battery selector switch. And Personally I would disconnect both batteries first.
                  this is the part I ordered. I’m glad the write up helped!​
                  https://nautiqueparts.com/battery-se...s-1-2-1-2-off/
                  1989 Sport Nautique
                  • uwhusky
                    • Aug 2006
                    • 320
                    • Salt Lake City
                    Would the Blue Sea switch also work? I'm wondering if the Nautique dealer does not have the Nautique part, can I substitute with a Blue Sea.
                    • ScooterMcgavin
                      • 1551
                      • 2014 SAN 210 TE
                      I would think this one would work if the 4 holes that keep it in place are in the same location as the one from Nautique
                      1989 Sport Nautique
