Struggling to find anything on replacing the shift override button (allows you to rev engine in neutral) for G23. Mine apparently is bad, I can’t ever get the boat to rev up in neutral even after pressing the override switch. Not sure if this button lights up after being engaged?
We also have random issues starting the boat and have to reset by pressing STOP multiple times or actually turning batteries off and back on. I’m assuming this override switch could cause that also.
Anyone else had issues with these shift override buttons? If so, is there a replacement? Service is pretty backed up and I’d like to fix this myself if possible.
Thanks for the help!
