2002 super air… check engine light starts to flicker and then once it stays lit it goes into a limp mode I’m guessing. Any suggestions on what’s going on or what is making the light come on? Thanks
Tags: None
Makes It easy, the gt40 hasOriginally posted by Fatboy1000 View Postyes gt40.
A temp and a oil sensor feeding the gauges and a high temp switch and a low oil pressure switch.
The 2 switches control the check engine light and limp.
Disconnect them one by one to see if it's to see if its low oil pressure or high temp.
I assume the gauges show correct readings.
The oil pressure switch is close to the high pressure fuel pump it's the smaller one.
The high temp switch is on top close to the thermostat I believe it's a green cable.
Both switches switch to ground to trigger the cel.
Sent from my SM-G892A using Tapatalk
