Hi all,
Couple questions around engine temps.
My analog temp gauge only comes up around the first hash on the gauge. Is that typical or should the needle be pointing straight up towards the halfway mark similar to how a car displays.
I know these gauges are based on resistance so if it’s considered normal they usually float around the halfway mark on the gauge.(I cleaned the sensor wires connection).
My other question was on the digital display on the tach what does ETStand for? Does that indicate engine coolant temp exhaust temp?
