A week ago, my 2007 216 with 5.7 330 Excalibur engine (700+ hours) was running extremely rough from ~9mph - 40mph, and wide-open topped out ~4400 rpm.
I replaced PCM FCC# RP080026 & also removed & cleaned the flame arrestor several days ago.
Immediately after the FCC change, I was able to get 4,900 RPM wide-open out of the boat ( I've never seen 5,000 ) and it ran well at ~34mph slalom speeds ( no skier ).
I then tried running it in kneeboard & wakeboard speeds (~9-20mph), and the engine is still missing, but not nearly as bad as pre-FCC filter change. While still out, I tried a 2nd run at wide-open, and it only got to ~4,700 RPM. I also tossed in a can of BG 44K to attempt to clean fuel injectors.
Now, I'm also detecting an occasional miss at slalom speeds, but not as noticeable as the slower RPMs.
Today, I replaced the Fuel Pre-Filter Kit ( RP077014 ), and there was some gunk in the old filter.
Engine still runs rough / misses after the pre-filter change (changed ~4 days after the FCC filter)
Did I replace the filters in the wrong order, and do I need do a 2nd FCC filter replacement?
Just trying to think what could cause me to loose 200+ max RPM in under 15 minutes after an FCC change.
The following are "2007 Factory Original". Would it by worth my time & money to change any of the following on a 14 year old boat with 700+ hours?
- Spark Plugs - RP030010 ( I have the original 41-993 with 700+ hours, not the newer 41-101's )
- Spark Plug Wire Set, 5.7L EXCALIBUR, PCM # RK120018
- Rotor Excalibur motors R103011
- Distributor cap GM EFI RA108009
While I've seem some forum posts where people claim to change these every 2-3 years, they aren't in PCM's recommended routine service.
Is a rough engine that doesn't get completely better with a FCC filter change a trigger to replace these parts?
The spark plugs visually appear fine with light gray, and no black soot (like I commonly saw on older-model 2-cycle PWCs).
Any other things I should do to troubleshoot or check for a rough running engine?
Thanks!
Thanks!
In both years, the boat has run fine with 93 gas that sat over the winter, but when I introduce the 89 or 90, it runs rough.
