2021G23 clunk sound
  • revolve77
    • Aug 2018
    • 58
    • Austin
    2021G23 clunk sound
    Looking for suggestions as to what I may be experiencing. I took the G out for a cruise yesterday and noticed a clunk sound coming from underneath the boat. The issue arises once I engage the throttle (going forward) after having it engaged from reverse to neutral. The clunk sound is not existent once I come off of plane and shift the boat into neutral and throttle back forward again. Im familiar with the clunk sound in reverse (which is normal) but am perplexed as to what could be causing this new issue. Any help or insight would greatly be appreciated.
  • zigs
    • May 2007
    • 109
    • ND
    • 2018 G21 2004 196
    Check your prop nut torque, and make sure the bigger nut in the middle of the shaft coupler off the v drive is tight as well.
