Hello was wondering if everybody else has experienced this error code ? I have a 2016 G23 and occasionally the boat goes into "limp" mode and throws this error code.
"Foot pedal position sensor 1 lower than foot pedal position sensor 2".
Turning the power on and off gets rid of the error and the boat will work again properly. I have already replaced the Livorsie/Throttle body unit twice actually (brand new one 3 weeks ago and known functioning version before that). However that did not do the trick, i am going to replace the cable/connection to the engine just to be safe, but yesterday while driving i pulled out the cables and gave them a good shake to check for loose connections. But it did not throw the error....
Thoughts on what else it could be ? thanks already !
