Hi All,
Just pulled the boat out for the summer and tried to fire it up in the driveway as i normally do to de-winterize. After getting water and everything hooked up, the boat will not crank over or start. Ran perfect at the end of last season and was winterized properly and stored inside (no visible wire damage) The dash and keypad lights light up and i can hear the fuel pump, but the boat wont crank over. After a little while of messing with it, i am getting a TPS fault, see dealer warning on the gauge. I contacted the local Nautique dealer and they are booked out through August. Its got the Excalibur 330 GM engine.
The following have been checked:
Any advice or help is much appreciated! hate seeing the boat sit in the drive while weather is getting perfect!
Cheers!
- Batteries in good shape: Even tried with Jumper box
- Tether is securely attached
- Batterie terminals and cables look good
- starter will crank over by jumping it (was replaced last season)
- Breakers are not flipped
- known fuses are not blown
- From what i can see grounds look okay
- I did notice that i left the knock sensor unplugged from winterizing, but is connected now with no change.
- Throttle seems to be functioning correctly
Cheers!
