2006 SANTE 220 Gateway Box location
  • MasonnosaM
    • May 2021
    • 20
    • Greenwood, MO
    • 2006 Nautique 220 Team Edition
    Can someone please tell me where this box is on a 2006 220?
  • ScooterMcgavin
    • 1551
    • 2014 SAN 210 TE
    I had an 06 210 and the gateway was behind panel at drivers feet. Check there
    1989 Sport Nautique
    • MasonnosaM
      • May 2021
      • 20
      • Greenwood, MO
      It's not there. There is an black box there that I wired the stargazer into but it's not the gateway box doesn't have pilot ports.
      • MasonnosaM
        • May 2021
        • 20
        • Greenwood, MO
        Ok, I have crawled in every nook on this boat, the only place I haven't looked is under the captain's chair. It's either so obvious I missed it or it's so hidden I have no idea. I have keyword search the forum with no answer.
        $20 Venmo to the first person to tell me where this elusive black box is.
        • biacs
          • Aug 2020
          • 269
          • Lake Benson
          • Raleigh, NC
          Takeoff the kick panel fuse board in front of the driver seat and it should be mounted to the back of the front cushion on the driver side
          • MasonnosaM
            • May 2021
            • 20
            • Greenwood, MO
            There is a black box mounted there, I guess I was looking for it to have the pilot tubes for the speedo but that must have been off older boats or a different model. When I looked up the post my gateway box didn't look like the ones posted. So basically when I did the Stargazer update that was with the Gateway box? There isn't another black box somewhere I am missing? Apologize for the ignorance but was trying to go off what was out there. Appreciate the response, PM me your venmo will drop you the $20.
            • TexasTom
              • May 2020
              • 128
              • Dallas, TX
              • 2018 G23 2006 SAN 220 TE (sold) 1999 GS185
              That is your gateway box. The 220 used the paddlewheel, not a pitot, therefore no pitot tube running to that box. Out pf curiousity, what are you looking to do in the Gateway?
              • MasonnosaM
                • May 2021
                • 20
                • Greenwood, MO
                Trying to troubleshoot 3 gauges that aren't working, volt, fuel and oil. Everything else on the dash works fine and the main reason is to get the fuel working so I can run down the tank close to empty. This will make it easier to move the gas tank and ballast tank back so I can change out the sender on the belly ballast.
                I hate to have to change out the whole dash for 3 -$30 dollar gauges but might have too. I read on Faria webpage they have a gauge repair service, do you know if they will repair the old gauges?
                • TexasTom
                  • May 2020
                  • 128
                  • Dallas, TX
                  They wont repair those gauges, I talked to them last year about it.
                  • Skidave
                    • 698
                    • York, PA
                    Our gauges are obsolete. I sent one in this April hoping to get lucky and they shipped it back saying no parts available.
                    Sent from my SM-J337V using Tapatalk
                    • biacs
                      • Aug 2020
                      • 269
                      • Lake Benson
                      • Raleigh, NC
                      Boaters code!
                      Just be sure you stop to help the next guy if he needs it lol!
                      • jkallen21
                        • Jan 2013
                        • 403
                        • United States
                        • 2006 Super Air 220
                        I also have the 220 SANTE and I have never seen any other black box besides the one at the driver kick panel either.
