PCM H6 sputtering under load
  • Speedy
    • May 2018
    • 153
    • Texas
    My apologies for my spelling, bad grammar and punctuation
    • zmnypit
      • Sep 2020
      • 158
      • Alabama
      • 2017 G23
      Originally posted by Speedy View Post
      You check the fusible links the same way you think a fuse. You should have battery power on both sides of the link. If there is no power on either side then you just keep tracing the wire back until you find power. Be sure to have the voltmeter on good battery ground. In other words you place the negative cable from the voltmeter on good battery ground and you use the positive cable from the voltmeter to check for power on the wire your tracing. You can also use a test light. By connecting it to battery ground and when you pierce the fusible link wire, the test light should light up
      Here's the few I've found on the front of the engine
      • Speedy
        • May 2018
        • 153
        • Texas
        if you have a test light then you can gently pierce the wire before and after the fuse. There should be battery power on both sides. It would be easier if I had a wiring diagram for the alternator circuit. but you should definitely have battery power on both sides of those fuses
        • zmnypit
          • Sep 2020
          • 158
          • Alabama
          • 2017 G23
          The bottom fuse is 125a. It's the wire that goes from the solenoid to the alternator no power I don't believe these fuses are serviceable as it looks like they are riveted together. It's got power in but no power out.
          • Speedy
            • May 2018
            • 153
            • Texas
            Are you saying that there is no power on either side of the fuse?
            • zmnypit
              • Sep 2020
              • 158
              • Alabama
              • 2017 G23
              #21
              No it has power on the inlet/short side off the solenoid. The longer end or where it runs to the alt has no power
              • Speedy
                • May 2018
                • 153
                • Texas
                #22
                Gotcha, you found the problem. I’m sure the new one will be a complete wiring harness that goes from the solenoid to the alternator. And you are absolutely correct in saying that that is not a serviceable fuse, it’s in fact a fusible link. It should be replaced as a complete harness
                • Speedy
                  • May 2018
                  • 153
                  • Texas
                  #23
                  You will still need to find out why the fuse failed. That is a 100 amp fuse which is a very large fuse, so I would still check and trace those big wires to make sure they are not touching ground. Otherwise the new fuse will fail again
                  • Speedy
                    • May 2018
                    • 153
                    • Texas
                    #24
                    Remember, the fuse did what it was supposed to do
                    • zmnypit
                      • Sep 2020
                      • 158
                      • Alabama
                      • 2017 G23
                      #25
                      Without a doubt. Once all this is replaced hopefully it fixes it all but I know my luck lately
                      • Speedy
                        • May 2018
                        • 153
                        • Texas
                        #26
                        For sure
                        • zmnypit
                          • Sep 2020
                          • 158
                          • Alabama
                          • 2017 G23
                          #27
                          Took the 125a link apart just for the heck of it. I'd say it's blown.
                          • Speedy
                            • May 2018
                            • 153
                            • Texas
                            #28
                            Are there any signs of the wire rubbing against ground?
                            • Speedy
                              • May 2018
                              • 153
                              • Texas
                              #29
                              Definitely an open fuse
                              • zmnypit
                                • Sep 2020
                                • 158
                                • Alabama
                                • 2017 G23
                                #30
                                Nope. Is is possible the alternator took it out when it died?
