How to run engine on trailer
  • DLarva
    • Jan 2012
    • 28
    • Minneapolis
    • 2012 200 Sport Nautique
    I have a 2012 Sport Nautique 200. I'm trying to sell it and a buyer wants to see the engine running. Where do I run water into to safely turn the engine on?
  • biacs
    • Aug 2020
    • 268
    • Lake Benson
    • Raleigh, NC
    • 2006 Nautique 220 Team Edition
    You need to go to a local marina or online and get something called a fake lake. It looks like a plunger essentially with an adjustable pole and you prop it up against your intake under the boat and attach the garden hose.
    Then you’re able to run the engine while water is being pumped into the intake through the impeller to cool the engine. Works fine.
    I recently learned that water also comes out of the propeller seal housing as part of the cooling process :-)
    • charlesml3
      • Jan 2008
      • 2487
      • Lake Gaston, NC
      • 2022 G23
      Agreed, just get a fake-a-lake. Your local service place may even just loan you one. They work just fine.
      • jmo
        • Mar 2006
        • 734
        • MA
        Just get a 1” diameter section of hose from Home Depot and connect it to the input side of the raw water strainer, put the other end in a 5 gallon bucket and feed the bucket from a garden hose.
        2018 Ski Nautique 200 TE, H6
        • jmo
          • Mar 2006
          • 734
          • MA
ID:	636746 Click image for larger version
ID:	636747 Here it is in action
          • DLarva
            • Jan 2012
            • 28
            • Minneapolis
            Thanks for the responses. I got it running with the fake lake. However, it gurgles. Is that typical? Or is it because I've got it hooked up wrong or the boat is at a decline because my driveway isn't flat?
            • charlesml3
              • Jan 2008
              • 2487
              • Lake Gaston, NC
              • 2022 G23
              The gurgling is fine. They all do that.
