I had my 1995 SNOB in the water all weekend (I normally trailer every day) and realized my bilge was filling up more than normal and not pumping out. I pushed the manual pump button and heard the pump running but no water discharged. I tried the automatic button and the same happened. When the pump was engaged and making noise I noticed that it felt like air was discharging out of the the normal discharge hole but still no water. Is there anything I should be checking or does this sound like a faulty pump that needs replacement? If replacement is in order, are there any recommendations for a good pump? There is a $16 500-gph pump on amazon that has great reviews, it just seems a little cheap so I wanted to confirm.
Thanks for any help you can provide!
