2001 SAN 210 eating impellers
  • GMac
    • Sep 2020
    • 6
    • Ft worth Tx
    • 2002 Super Air Nautique 210 2018 Phoenix 721
    So I have searched and haven’t found anything to help me figure out my issue. I have a 2001 SAN 210 with 5.8 PCM motor. I replaced the impeller a few weeks ago and took the boat out, everything worked great. Took it back out today and started it up and was watching the temp gauge before leaving. I set there about 3 minutes and the temp started to go up. I watched it until it hit 200ish and killed the motor. I took the hose off the impeller housing to see if water was getting to the impeller and it was dry. All the fins from the impeller were sitting in the housing or pushed through the system I assume. Well I had a spare impeller and swapped it out and it did the same thing. Any help would be much appreciated.
  • MTRBTR
    • May 2012
    • 485
    • MT
    Is pump on backwards/upsidedown? Easy to do on that engine
    2006 SV 211 (Sold)
    97 Sport Nautique (Sold)
    89 PS 190 (Sold)
    75 MFG (Sold)
    • GMac
      • Sep 2020
      • 6
      • Ft worth Tx
      I don’t think so but could be wrong
      • Nautiquehunter
        • Jun 2008
        • 2099
        The pump should mounted with the hoses on the pump lining up closes to the block. Make sure you only buy a Sherwood impeller there are a lot of junk Chinese impellers around . Nautique Parts or Skidim are good to deal with.
        • GMac
          • Sep 2020
          • 6
          • Ft worth Tx
          Both impellers were Sherwood
          • swatguy
            • 1666
            • Midwest/ Northern IL
            • 2008 SANTE 210
            Did you flush your system after it ate the impeller, or did you simply put in a new one ?
            if you didn’t flush system and clean out old pieces( because they will be in there) most likely those left over pieces will eat up the née one too
            • Jonny Quest
              • Aug 2014
              • 464
              Perhaps something was ingested into the raw water intake. I have seen a plugged raw water intake cause cooling problems before. I once saw a plastic grocery bag get sucked up into a raw water intake that caused the owner a lot of grief.
