2006 220 TE- Remove Muffler -so I can access Impeller- or move muffler back further?
  • biacs
    • Aug 2020
    • 268
    • Lake Benson
    • Raleigh, NC
    • 2006 Nautique 220 Team Edition
    Hi all,
    I got this 220 in July, so I ran it mostly as-is. It needed plenty of TLC this winter (steering cable was a learning curve). It has ~600 hrs. Impeller was pretty roached, but my muffler sits right up against the impeller (less than 1" gap). I plan to replace impeller yearly, so I DONT want to pull exhasut risers and muffler out each time. Very heavy and exhasut riser gaskets were ~40$.
    Here's what I need to understand:
    • Do 2006 guys straight pipe and remove / delete muffler for easier impeller access?
    • Should I cut longer exhaust tubing and shorten the lower exhasut tube at the stern (to offset the muffler back a few inches farther back so I can access impeller) ?
    • Was there a service tech trick to access impeller as-is for service?
    Any option is feasible, but I hate to have a poor design win the day!
  • TexasTom
    • May 2020
    • 128
    • Dallas, TX
    • 2018 G23 2006 SAN 220 TE (sold) 1999 GS185
    Do you have a photo of this? I also have a 220 with the ZR6 And access to the raw water impeller hasnt been an issue.
    • charlesml3
      • Jan 2008
      • 2487
      • Lake Gaston, NC
      • 2022 G23
      Agreed. There should be no reason to remove exhaust risers to get to the impeller housing. I've never had to do that on any Nautique.
      • zbielling
        • Jul 2012
        • 17
        • Jacksonville, FL
        • Super Air Nautique 220
        I have an 06 220 with an Excalibur 330. It is tight but you can get it out and back in without removing the muffler. I do it every year. If i remember correctly, you have to remove the pulley/cover assembly while the impeller stays in. then use a pair or 90 degree needle nose pliers to remove the impeller. For reinstall, the impeller first then slide the pulley/cover back on.
        • biacs
          • Aug 2020
          • 268
          • Lake Benson
          • Raleigh, NC
          First of all THANKS for taking time to reply!!
          • I have the 5.3 engine, I believe
          • My room to work is about 1" of clearance (lol the serp belt gets hung up in the gap)
          • my exhaust plumbing is SIEZED to the muffler and risers, so I removed all together - saw others do this researching my steering cable install
          Here is a ideal solution - so please let me know. ->
          • Can I get more flexible material to connect the risers and muffler? Something more pliable and rubbery?
          If I could easily disconnect the muffler and riser, it would be easy-peasey! As the boat is fairly new-to-me, I'm OK with fixing/addresing all these small things that I need to as time goes on. Like the exhaust all being stuck together :-)
