Should you grease the slide portion of the steering cable that attached to the rudder? I was going to install a new cable this weekend but after getting access to the rudder and cable and reviewing the area of cable that slides in the sleeve I noticed a little bit of dirty/grime. It was a small amount and I was able to clean it off and it does seem like it helped a bit on the smoothness of the cable, I also greased the rudder. My question is should I put grease on the slide portion of the cable? It doesn't appear that there was any there before.
