Excaliber 330 engine hood fix?
  • SilentSeven
    • Feb 2014
    • 2211
    • Bellevue WA
    • 2004 Nautique 206
    So the screw holes are blown out on my engine hood. Has anyone tried to re-enforce these with some material? How did you do it?
    Bellevue WA
  • SilentSeven
    • Feb 2014
    • 2211
    • Bellevue WA
    • 2004 Nautique 206
    Also - are these the correct mounting screws? It seems like the PO used some non standard nuts for the hood.
    https://www.nautiqueparts.com/produc...cm-gm-engines/
    Bellevue WA
    • Stevemo14
      • Apr 2019
      • 691
      • Columbus, OH
      These are what mine uses
      https://www.nautiqueparts.com/produc...of-cover-5-7l/
      • SilentSeven
        • Feb 2014
        • 2211
        • Bellevue WA
        • 2004 Nautique 206
        Yeah...ok, that's what's on mine. Never would have guessed that's the right part.
        Is there some sort of 'thing' that fits in the engine cover recessed divot to distribute the nut load? I don't understand how that shape of nut is supposed to really hold down the cover...
        Bellevue WA
        • Stevemo14
          • Apr 2019
          • 691
          • Columbus, OH
          Mine only uses those nuts.
          • MN Ryan
            • Aug 2020
            • 1394
            • Maple Grove, MN
            • 2007 SV-211 TE
            Mine uses the same ones that stevo posted. I don't know how the cowling on yours cracked like that. They work fine on mine. There's really no stress on it--it is basically a decorative cover.
            • SilentSeven
              • Feb 2014
              • 2211
              • Bellevue WA
              • 2004 Nautique 206
              Right. It's weird. I'm gonna fab up some simple bushings with my 3d printer and see how that works.
              Sent from my Pixel 3a using Tapatalk
              Bellevue WA
              • MN Ryan
                • Aug 2020
                • 1394
                • Maple Grove, MN
                • 2007 SV-211 TE
                Yeah, I would think one could fashion up a solution fairly easily.
                • SilentSeven
                  • Feb 2014
                  • 2211
                  • Bellevue WA
                  • 2004 Nautique 206
                  OK. Here's a quick fix. Bushings work nicely. Printed from PLA so we'll see how they do with engine heat; may need to reprint with ABS.
                  Here's a bushing next to an installed version.
                  Click image for larger version  Name:	PXL_20210415_001055396.jpg Views:	0 Size:	42.6 KB ID:	634814
                  Click image for larger version  Name:	image_56875.jpg Views:	5 Size:	38.2 KB ID:	634815
                  Click image for larger version  Name:	PXL_20210415_004106565.jpg Views:	0 Size:	57.2 KB ID:	634817
                  Finished job. That looks better and it's more secure...doesn't flop around like it did before.
                  I can't upload the STL but it anyone wants it, just send me your email on a DM and I'll pass it along.
                  Bellevue WA
                  • MN Ryan
                    • Aug 2020
                    • 1394
                    • Maple Grove, MN
                    • 2007 SV-211 TE
                    Looks great!
                    • Warrior48188
                      • Aug 2017
                      • 25
                      • Michigan
                      • 2004 SAN
                      SilentSeven - I have the same issue on my 330 Excalibur. I'll shoot you a PM to obtain the specs. Click image for larger version
                      • dkimball
                        • Aug 2008
                        • 125
                        Can the studs be easily replaced that the nuts screw too? On my 216 the previous owner must have really wanted them to stay on because he stripped the threads off of 2 of the 3 studs. I just wrapped some duct tape around the stud to hold the nut in place which has worked fine for the 3 years I have owned the boat.
                        • Stevemo14
                          • Apr 2019
                          • 691
                          • Columbus, OH
                          I don't 100% remember, but I think the studs go through the flame arrestor and into the throttle body. I'm not really sure past that. My guess is the studs thread into the intake, the throttle body is slide over, then bolted down. The flame arrestor is then slid over, and the engine hood put on, then the hood bolts hold both of those down.
                          • Stevemo14
                            • Apr 2019
                            • 691
                            • Columbus, OH
                            This could be what you are looking for.
                            https://www.nautiqueparts.com/produc...stor-hood-5-7/
                            • MN Ryan
                              • Aug 2020
                              • 1394
                              • Maple Grove, MN
                              • 2007 SV-211 TE
                              Yes, they're easy to replace, and the link that Stevemo shared is the part you need. Kind of pricey for what they are, but...
                              I had to replace one on my SV211 last fall.
