Hi all,
I just completed upgrading my 04 Air Nautique to Zero off. New wiring harness, ECM, throttle body and I went ahead and updated the faria box as well. I now have a dead oil pressure gauge as well as tach. Nothing works on the tach..completely dead. Any ideas as to what might be causing this? My oil pressure gauge actually quit the last time I fired it up to load it on the trailer to do the conversion so thinking the gauge just might be bad? New sending unit (came with upgrade) made no difference. I grounded the blue wire on the oil pressure harness at the sending unit and the gauge does nothing. If it is the gauge does anyone have one that they have removed from their boat due to the gateway box failure? If so I'd be interested in purchasing it from you...actually I'd be interested in any of the gauges anyone has just to keep as a back up since I went with upgrading the gateway box. Thanks!
