2018 g 25 ballast pump sensor fault
  • Bsamg25
    • Mar 2021
    • 7
    • Cusick wa
    • 2018 g25
    Looking for info on ballast pump sensor. Location, repair? Spring start up, starboard ballast tank showing full with no water in it. Both port and starboard showing 4 volts. Tried unplugging pumps, disconnecting batteries, no change. Wondering if I try to discharge my pump to where tank shows 0% will it burn up my pump?
    • 16870
    It won't burn up the pump, but it may damage the impeller.
    The weight sensors on the ballast bags are a known issue. I'd just have it replaced under warranty.
    • Bsamg25
      • Mar 2021
      • 7
      • Cusick wa
      • 2018 g25
      Thanks Jeff, I’ll see if I can find the impeller replacement. I opted not to pay the $3000 dollars to continue my warranty with nautique when I bought my boat. Very frustrated with that whole transfer of ownership. So if I can fix it I will!! You guys are great people with great info.
      • GMLIII
        • May 2013
        • 2816
        As Jeff stated these ballast sensors are a known problem for Nautiques. I had to replace the ones on my G23, and they were replaced under warranty. I will warn that they are extremely difficult to change and that is what my dealer told me. I would not recommend trying to replace them on your own.
        • Bsamg25
          • Mar 2021
          • 7
          • Cusick wa
          • 2018 g25
          Thanks for the info, my local dealer is a POS, money hungry, inexperienced staff etc. if it can be done by the dealer it can be done by me, I love a good challenge. Just because you save for a long time to get a beautiful boat like ours doesn’t mean you should get raped by the dealers. I’m sure there are a few more people that follow this forum that feel this way. Thanks again for the help!
          • GMLIII
            • May 2013
            • 2816
            Bsamg25 , I do recall my dealer telling me he had to make a special tool to remove the ballast sensors . Basically he had to saw off part of the socket wrench handle to make the turns with the handle. I wish you luck in the difficult task ahead of you
            • ESP
              • Feb 2021
              • 25
              • Regina Saskatchewan Cananda
              • 2020 GS22
              Try this, the sensor has been changed to a newer version as the original were not very reliable.
              https://www.nautiqueparts.com/wp-con...son-Sensor.pdf
              • Bsamg25
                • Mar 2021
                • 7
                • Cusick wa
                • 2018 g25
                Ordered two new sensors today, love how they went from $100 to $300, they offer software update as well. As soon as I get them and have the chance to do the swap I’ll try to film and document them to the best of my ability for the rest of the group having the same issue. Cheers!
                • Blomdoggy
                  • Oct 2019
                  • 25
                  • American fork utah
                  I have Replaced a couple Ballast sensors when I worked for a Dealer, and they are not fun! The Port and STBD Sensors are in the Very back corners of the Engine Compartment, and are a Pain to get to, we had to take the Back Side Panels off to be able to reach them. Once you can reach them though, all you have to do is get a wrench, and take it out, Unplug it, and Plug the new one in and install!
                  The Ballast sensor for the Belly Tank is a Little better but still hard to reach, It is in the either in the Love Seat Storage area or right below the Drivers seat under the Aluminum Plate, I can't Remember.
                  Wasn't to hard to do but it was hard to figure out how to be able to access and reach them!
                  • Bsamg25
                    • Mar 2021
                    • 7
                    • Cusick wa
                    • 2018 g25
                    Thank you for the info, I’m sure it won’t be fun. Like surfing with out ballast!
                    • gonefishin5555
                      • May 2018
                      • 114
                      • SoCal
                      • 2017 GS22
                      I only paid $800 total back in 2018 to transfer both warranties. Crazy if it really went up that much. We used it to replace the throttle assembly about a 1K repair. I have it at the dealer now for service and I do have a tank not draining...pretty sure its the ballast sensor. They gave us some blowback when we dropped if off so we will see what they say.or if they step up and fix it
                      • Bsamg25
                        • Mar 2021
                        • 7
                        • Cusick wa
                        • 2018 g25
                        The guy I bought the boat from already had it winterized, we fired it up for two days at lake Powell to test it out, I came home and winterized it again. Dealer said they would have to summerize it to do all the systems test. So that those fees, plus there warranty transfer fees, and shop fees, etc, etc, etc. for being a faith based company they sure know how to squeeze you for money. It really sucks, been dreaming of this massive beautiful machine for years, $$$$$$$$$
                        • gonefishin5555
                          • May 2018
                          • 114
                          • SoCal
                          • 2017 GS22
                          I did a private party deal. I just filled out the transfer paperwork off the nautique site and sent them the money. There is no inspection or dealer fees required so yeah they probably werent busy in the service dept at the time of your purchase.
                          • Bsamg25
                            • Mar 2021
                            • 7
                            • Cusick wa
                            • 2018 g25
                            That would have been a great option, neither dealers mentioned that for my private party sale, they just both asked for my credit card.
                            • tdbaugha
                              • Mar 2021
                              • 25
                              • Flathead
                              • None
                              That’s pretty unfortunate that the dealers didn’t mention how simple it is to transfer the warranty. Good luck with your repairs!
