Heater switch control on 04 Air Nautique Limited with keypad
  • tdub59
    • Mar 2019
    • 7
    • Shelby NC
    • 2004 Air Nautique 216 Sport Limited
    Adding heater to my boat and can't find a suitable schematic that shows where to tap in to 4 wires for power/low/med/high. Schematic I can find shows a 4 pin connector on the harness for a direct plug in, but can't find it anywhere. Any help is much appreciated!
  • Skidave
    • 697
    • York, PA
    My 2003 heater wire was bundled in with the main harness under the kick panel. It is a medium's sized four pin molex connector.
    Sent from my SM-J337V using Tapatalk
    • tdub59
      • Mar 2019
      • 7
      • Shelby NC
      I've dug around that harness as much as I can without actually starting to cut away all the tape and conduit. Did you have to cut open the harness at all to find it?
      • Skidave
        • 697
        • York, PA
        Nope. It was a separate 4 wire bundle coming out of the harness with its own split-loom tubing.
        • tdub59
          • Mar 2019
          • 7
          • Shelby NC
          FINALLY found it! Had to cut a bunch of zip ties and some electrical tape. They had it folded in and taped up in the middle of the harness. The male plug was with it which worked out great as the plug on my fan was different. They had a resistor soldered in from one lead to another...not sure why but made up the plug and it works great.. Thanks for the help! T
