Which plug wires, cap, and rotor, for 95 GT40???
  • ricoshred
    • Sep 2003
    • 25
    Time for a tune up on my 1995 Super Sport GT40. Does anyone know which stock ford plugs, cap & rotor, plugs, etc. will work? Wanting to go to autozone. Thanks for your help!!
  • Peter6000
    • May 2017
    • 168
    • northern Virginia
    • 1999 Ski Nautique
    In general everything from a ford bronco 5.8 will fit, however the ignition wires are to short due to the big exhaust manifolds.
    You may want to consider the marine ones.
    Sent from my SM-G892A using Tapatalk
    • hal2814
      • Jun 2016
      • 550
      • Ft Worth, TX
      • 2026 G23 Previous: 2022 G23, 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
      For plugs I used Autolite 764 on my GT40. Can’t help with cap and wires. There are marine-specific versions of those so that’s what I buy.
      • gary s
        • Mar 2015
        • 335
        • Algonquin IL
        You can also use 93-95 Ford Lightning as a reference as well. Look for a cap that has brass terminals rather than aluminum and put RTV into the hole that the black cap for a vent is. Wires will have to be custom made or if you want to plug and play Nautique parts or a PCM dealer
        • bturner
          • Jun 2019
          • 1774
          • MI
          • 2016 200 Sport Nautique
          Or call Discount Inboard Marine and have them set you up. May cost a bit more and take a bit longer but it's not like you buy this stuff every year. The local Autozone for plugs sure but the wires, cap and rotor I would probably get the correct stuff but that's just me.....
          https://skidim.com/?SID=9f4e3r43u85dnqv49ofdtt7tl5
          • gary s
            • Mar 2015
            • 335
            • Algonquin IL
            Its just you . If you look at their picture of the cap it's the same one that has been used on Ford cars and trucks for decades. I've been told to put RTV in that black cap but have never bothered. Might as well save the money and get one locally.
            PCM Distributer Cap & Rotor PCM GT40 RP173082: Fits: 95 and up PCM EFI Ford
            • gary s
              • Mar 2015
              • 335
              • Algonquin IL
              Here is Nautique Parts pic-
              • ricoshred
                • Sep 2003
                • 25
                Ok Thanks for the help fellas
                I'm thinking I can get by with plugs, cap, & rotor only. Hoping the wires are still ok.
