Can’t figure out what plug and where it connects on PCM GT40
  • Marinshamrock
    • Mar 2021
    • 11
    • Marin County
    • Shamrock 200 Cuddy
ID:	633767Click image for larger version
ID:	633766Click image for larger version
ID:	633765I can’t seem to figure out what this plug is for and what it plugs into I traced it back with the volt meter and found it’s grounded on the connections I marked with a sharpie on the ecm if anyone know please let me know it might be the source of my loping idle
  • Jonny Quest
    • Aug 2014
    • 457
    You may want to give this a try on www.CorrectCraftFan.com and see what those old-school guys say. You may want to provide a bit more info, such as engine model year and any issues / symptoms you may be having with the engine.
    JQ
    • Nautiquehunter
      • Jun 2008
      • 2099
      Does it still have a distributorless ignition ? The big conector looks like it plugged into the coil pack.
      • mpost
        • Jun 2007
        • 144
        • Monticello, MN.
        • 98 SN GT40
        Look at this diagram.
        https://planetnautique.com/CorrectCr...entHarness.pdf
        the pins you have marked on the ecm harness look to be 20,40,& 60 which are ground, and 8 & 30. Pin 8 looks to go to the fuel pump pressure sensor?
        1998 SN GT40
        84 2001 Ski Nautique (sold)
        Monticello MN.
        • gary s
          • Mar 2015
          • 335
          • Algonquin IL
          Green wire is the S.L.O.W. system. Should be plugged into a green wire leading to the dash light located near by the 8 pin engine to boat harness
          • gary s
            • Mar 2015
            • 335
            • Algonquin IL
            Just saw your screen name. Whats the story with a GT40 and a Shamrock? I'm in the process of putting a 40 in my Shamrock 20ft WalkThru as well.
            You won't obviously have a green wire going up front to a light. The S.L.O.W. system senses if you have an overheat or low oil pressure and puts the engine into a safe mode which limits RPM and turns on the light on the dash.
            • Marinshamrock
              • Mar 2021
              • 11
              • Marin County
              Thanks guys for all the info would the slow system make it pipe at idle if the wire was not connected
              • Marinshamrock
                • Mar 2021
                • 11
                • Marin County
                Also Gary the GT40 in my shamrock 200 Cuddy makes the thing fly is so over powered I’ve got it up to 45 on gps fully loaded and it was terrifying and if I didn’t have 2 people a live bait tank and a 300lbs cooler with wind it would have probably gotten up to 50+ I’ve got a speed prop for it but have no plans of putting it on
