PCM GT40 Idle surging Please help!?!?
  • Canuck-Surfer
    • May 2019
    • 181
    • Ontario, Canada
    • 08 Nautique SV211 96 Sport Nautique
    Emil,
    I suspect the same thing on my engine as well. Over the last week I’ve replaced everything. Tonight I replace the map and the bypass valve. I did not clean the filter. Tomorrow my plan is to clean the filter but if that’s not it I’m out of ideas on mine as well. I’m also having a hard start issue that I had hoped replacing all of the other components would have resolved. The only thing I haven’t touched at this point is the injectors. I’m pretty close to pulling the trigger on ordering a new set from Summit.
    • ibelieve
      • Aug 2006
      • 14
      • High Rock Lake, NC
      • 2000 SN 196 2004 Malibu Response LXi
      Sorry but I have been away. Thanks for the description and suggestion. It will take a look!
      • phillik
        • Jul 2022
        • 12
        • Alabama
        • 1999 Air Nautique
        Originally posted by Canuck-Surfer View Post
        Emil,
        Before you drop that cash on new ones, send your old ones off to be tested. We used Fuel Injector Clinic in Florida. The price was very reasonable and they were able to bring our old ones back to life.
        Also for sensors, this video is a good one for testing with an ohm meter.
        Sensor video:
        https://youtu.be/hFmI-_B9IVs
        • ibelieve
          • Aug 2006
          • 14
          I removed all of my injectors and built a little jig with a 9V battery and switch, to energize them with a can of carberator cleaner connected to the injector. Push the switch to open the injector and spray the cleaner at the same time. I was able to find one that was clogged and after a few tries it opened up and has been working for years. Not sure if I have pics but will see what I can find and post it here.
          /Steve
          Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
          • ibelieve
            • Aug 2006
            • 14
            Asking about the by-pass valve. If I blow in one side, there appears to be some air that passes thru. I assume this should not be the case. Can I engage the valve with a 9V battery or other 12V source in order to clean it? I need to open or operate it in some way to try and clean the valve seat. Either that, or buy a replacement.
            Thanks,
            Steve
            • ibelieve
              • Aug 2006
              • 14
              #21
              To operate the by-pass valve, you need 12V. Polarity only matters as it has to be correct to open. If you have it reversed, it just tries to close it more ... seems a bit odd. I have mine actuating and cleaned. I'll see what happens with the idle when I get it all put back together.
              Thanks everyone for all the help. I will post info on the injector cleaner under a new DIY topic ... https://www.planetnautique.com/vb5/f...jector-cleaner
              /Steve
              • phillik
                • Jul 2022
                • 12
                • Alabama
                • 1999 Air Nautique
                #22
                /Steve
                That's very cool and really like your DIY. To be honest I looked into this but got cold feet when I read about side effects of doing this. Not saying that is true and I really don't have experience building a test jig like that. It was enough for us to send them off.
                I'm not sure if these are the right injectors. In some research I found that Bosch has a new version that went from blue top to gray top. Part# 0280150965
                https://www.fiveomotorsport.com/bosch-0280150965-24lb/
                I think these are also in some 1995-1996-1997-1998-1999 Mitsubishi Eclipse. If you search for them online, I found some really cheap ones for ~$17.00 per injector!
                Would love to know if these would work as backup or to upgrade to a 4 port one.
                /Kyle
                • FMSKI
                  • Aug 2010
                  • 244
                  • Sproat Lake
                  • 07 SV211 Ex330 Ski 'n Surf Sold (Ski 200, TSC1, 2001)
                  #23
                  RE: Injectors - 9V battery is a nice trick. Noted in the manual, the coil of the injector will burn if 12volts is applied directly. I cleaned up Porsche/Bosch injectors, using same idea with cleaner and some compressed air. An engine that sits is prone to fuel issues and clogged injectors. But using that trick you can totally see them work properly after cleaning.
                  • slhayes10
                    • Jan 2025
                    • 2
                    • Boise Idaho
                    #24
                    Originally posted by Emil View Post
                    I have this same issue, but with one big difference I think, I have surging AND am running quite rich at idle. I’ve replaced all the sensors, relays, etc. Has anyone else had this issue plus the rich fuel mixture? My theory is currently leaky injectors, because my plugs were noticeably blacker on cylinders 1,4, and 8. I have 40psi on the rail with the key on engine off, regulator is new as well.
                    Hi Emil,
                    I am trying to troubleshoot my 2001 SAN that is having the exact same issue described by you here:
                    "I have this same issue, but with one big difference I think, I have surging AND am running quite rich at idle. I’ve replaced all the sensors, relays, etc. Has anyone else had this issue plus the rich fuel mixture? My theory is currently leaky injectors, because my plugs were noticeably blacker on cylinders 1,4, and 8. I have 40psi on the rail with the key on engine off, regulator is new as well."
                    Just curious if you found a resolution. I have changed almost everything including the injectors. Any input would be a huge help.
                    • Jonny Quest
                      • Aug 2014
                      • 464
                      #25
                      I think you are on the right track with leaky injectors. Ford performance makes some nice replacement/upgrade injectors. Might be worth a look.
                      https://lmr.com/item/M9593LU24A/1986...s-M-9593-Lu24a
                      A set of 8 is usually around $250.
                      you will also need a set of these EV1 to EV6 adapters
                      https://www.summitracing.com/parts/b...kaAiBsEALw_wcB
                      I did this to my 2001 SN with a GT40. Very happy with the results.
                      • slhayes10
                        • Jan 2025
                        • 2
                        • Boise Idaho
                        #26
                        I installed these last year utilizing the EV1 to EV6 adapters. I suppose one of them could be bad. I'll double check this afternoon. Thank you for your feedback!
