Faria Gateway Gauges Running Out for Replacements
  • ScooterMcgavin
    • 1551
    • 2014 SAN 210 TE
    Greg, Have you seen this thread?
    https://www.planetnautique.com/vb5/f...-faria-gateway
    1989 Sport Nautique
    • WakeHawk
      • Feb 2016
      • 55
      • Washington
      • 2008 SANTE 210
      Here is how I fixed this issue with my boat:
      https://www.planetnautique.com/vb5/f...ith-garmin-mfd
      Won't mess with anything Faria again.
Name:	2022-04-15 13.20.17.jpg
      • MN Ryan
        • Aug 2020
        • 1398
        • Maple Grove, MN
        • 2007 SV-211 TE
        WakeHawk I truly wish I had your skills/abilities as that is really a cool solution.
        • SKI-224
          • Oct 2007
          • 7
          • Houston TX
          Hey guys, does anyone knows if GW0021 is compatible GW0020
          i have an 2007 SV211 and the gateway box is bad and the replacement gages are horrible
          I’m hopping the the 21 box will work with the 20
          thanks​
          • jonnydeez
            • Mar 2015
            • 46
            • Austin
            • 2007 Super Air Nautique 220 Team Edition
            Echoing SKI-224 question. Does anybody know if the GW0021 will work on a 2007 SANTE 220. Original gateway on this boat is GW0020A. Called Nautique parts and they have a list of 180 people waiting for the conversion kit, and are about 1 year out on sending any.
            • bturner
              • Jun 2019
              • 1790
              • MI
              • 2016 200 Sport Nautique
              #21
              I should probably stay out of this as I don't have a background with this issue but has anyone considered the TRD conversion kits or will these not work on the boats in question.....
              This one is for a 2008 Ski Nautique but it says they have other models available. I would think they should be similar with the exception of the cable lengths, no?
              https://skiboatpartsonline.com/Medal...ia-SBE-2001-CC
              • Boats Bros
                • Mar 2023
                • 146
                • Texas
                • 2009 SANTE 210 Full Throttle 2003 SANTE 210
                #22
                I just purchased a 2003 SANTE 210 and all the gauges work to my knowledge, should I go ahead and unplug the speedo tubes from the gateway box to save a future ruined gateway box? I didn’t use the speedo much in my last boat, and plus doesn’t the perfect pass display speed anyways?
                2009 Super Air Nautique 210 Team ZR-409
                2003 Super Air Nautique 210 Team Edition
                1994 Sport Nautique
                • bturner
                  • Jun 2019
                  • 1790
                  • MI
                  #23
                  So there's a couple thoughts here.....
                  The first would be on disconnecting the speedo tubes. I personally would and yes the PP has speed in it as well from the paddlewheel or GPS depending on what PP you have.
                  That said I'm too much of a "it all has to work and correctly' type of guy. If I disconnected the speedos and just left them dead in the dash it would drive me absolutely nuts. I would have to replace them with GPS speedos so I could sleep at night. This however would probably put me in another dilemma as I would need all the gauges to look the same. So moving down into that rat hole I would either take the speedo gauges to a gauge shop and have them converted to GPS or replace everything (yeah, I'm that bad). If I replaced everything I would probably go with the skiboatpartsonline set up, suck it up and get it done. I would then offer up a working Gateway box for sale and try to recover as much of my cost as possible. But that's me.
                  • Boats Bros
                    • Mar 2023
                    • 146
                    • Texas
                    #24
                    Boats Bros Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
                    So I tested the boat yesterday, the speedo works for a second and dies immediately after. It continued this pattern the entire time I was on the lake. Since it doesn’t work properly I’m just going to disconnect them.
                    Do you have a link to the GPS kit? I used to work on boats and I installed one on a customers boat a few years ago, but they were the analog gauges from the mid 90’s Nautique. They worked flawlessly though.
                    1994 Sport Nautique
