First Time Winterization
  • Lucenut
    • Jun 2016
    • 7
    • La Crosse, Wisconsin
    1990 Nautique
    So I bought a 1990 Ski Nautique this summer. It has about 8 drain tubes in various places on the motor and manifolds. I have a fitting to run a garden hose in for dry land running. I was thinking of running a few gallons of RV anti-freeze into that port until it's coming out of the exhaust pink. Then opening all of the drain pet-cocks and maybe blow some air into the garden hose port to get as much of the fluid out as possible. Is that the right way to go, or should I drain any water out of the drain tubes FIRST, then run anti-freeze through and leave it in the motor/manifolds without draining?
  • hal2814
    • Jun 2016
    • 550
    • Ft Worth, TX
    • 2026 G23 Previous: 2022 G23, 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
    Correct Craft manuals state to drain the engine at the drain points and then pour antifreeze in through the hose going to the thermostat. That’s what I recommend and what I do. There are other techniques that work well for people. I just don’t have experience with them. The most important thing is getting water out. The next most important thing is preventing corrosion by getting a non-freezing liquid in.
    • Lucenut
      • Jun 2016
      • 7
      Sorry to be dense, but there are 4 hoses from the thermostat housing. The 2 top hoses go to the manifolds. Not sure what the other 2 go to. Which one do you pour the anti-freeze into?
      • hal2814
        • Jun 2016
        • 550
        • Ft Worth, TX
        Pull the hose from the water pump to the thermostat.
