Software Updates for 2013 G23?
  • SCNautique210SAN
    • Mar 2011
    • 194
    • SoCal
    • 13 G23 04 SAN 210TE 92 Sport Nautique
    Hey guys,
    Pretty new to the system that's on the G23s. I have a 2013 and was curious if there are updates to be made to the Linc system via USB. Has anyone done this and know where to find downloads for the Linc system if there are updates?
  • nohlan_4
    • Jan 2016
    • 420
    • Canada
    • 2013 G23 450
    I’ve done it. Got the files from the dealer. But generally if it’s working ok then just leave it as is. You don’t gain any additional features or anything by updating it. Only reason I did mine was I had an issue with my gps and they wanted to rule out the screen software.
    • robertsmcfarland
      • Oct 2004
      • 544
      • Hyco
      • 2014 g23 550
      i'm with nohiam I have had couple of up grades over the years but never saw any changes to boat or instruments would be interesting if they would tell you what the up grades do like apple does at least you have something to look forward too... your dealer can send up grade to your computer and you can put on a finger flash and then insert in boat to down load...
      2013 G23 super air
      2010 230 super air
      2009 220 super air
      2008 210 super air
      2005 210 super air
      2003 calabria pro air
      • hal2814
        • Jun 2016
        • 550
        • Ft Worth, TX
        • 2026 G23 Previous: 2022 G23, 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
        The only thing I can think of that you may need an update for is when your ballast sensors go kaput. The new ones require an update.
        • SCNautique210SAN
          • Mar 2011
          • 194
          • SoCal
          Thanks guys. I did have one fluke on the water where I filled all ballast up and for some reason or another the belly wouldn't empty. Pumps were running fine and I just changed the impellers so couldn't have been a pump issue unless something was clogged down below. But it felt like a bug. Eventually it drained but it took a couple cycles on and off and then about 20 minutes of draining.
          Not 100% sure if it was software related, could have been a sensor. So in the case that a sensor needs to be replaced there's some form of programming that needs to be done to get it to read properly?
          • nohlan_4
            • Jan 2016
            • 420
            • Canada
            • 2013 G23 450
            If the pump was physically running then that’s not a software issue. Did you confirm the pump was running or it took a bunch of cycles for it to kick on?
            • SCNautique210SAN
              • Mar 2011
              • 194
              • SoCal
              Yea the Pump was running for sure. No issues there. Just wouldn't drain for one reason or another. Or it was draining and just wasn't reading properly in the ballast readings
              • nohlan_4
                • Jan 2016
                • 420
                • Canada
                • 2013 G23 450
                I would say that’s an impeller issue or something clogged in the pick up tube. You can hear when the pumps start to run dry it’s a very distinct sound I would say your software is fine.
                • SCNautique210SAN
                  • Mar 2011
                  • 194
                  • SoCal
                  nohlan_4 yea I'm thinking something is clogged. I replaced all the impellers for the three pumps this season. If something is clogged in the pickup tube would it impact all pumps or are there independent pickup tubes on these Gs like the older generation boats (don't remember what the underside of the hull looks like).
