prop reaming
  • Nautimech226
    • Jun 2017
    • 8
    • Syracuse
    • 05 air nautique 226
    prop reaming
    On the older Gs you had to ream the prop if it was brand new. Does anybody know what year you could stop doing that since they have updated the shaft a few times since then?
  • Jonny Quest
    • Aug 2014
    • 464
    Reaming? I assume you are referring to lapping the prop to the taper of the shaft. That really is the correct way to mount a new prop onto a tapered shaft. The woodruff key is not what keeps the prop and shaft properly joined, but rather the tapered fit of prop/shaft.
    JQ
    • gonefishin5555
      • May 2018
      • 114
      • SoCal
      • 2017 GS22
      Sounds painful
      • hal2814
        • Jun 2016
        • 550
        • Ft Worth, TX
        • 2026 G23 Previous: 2022 G23, 2021 GS24, 2011 Super Air Nautique 230, 1995 Super Sport, 1983 Ski Nautique
        On a tapered shaft you probably should lap the prop any time you change it to get the best fit. All you need is some valve grinding compound and Prussian blue and about 15-30 minutes of time. If you need to ream it, you have the wrong prop.
