Announcement
No announcement yet.
HELP GT40 2001 SAN surging after running high RPMs
  • Peter6000
    replied
    Originally posted by Danny Roberts View Post
    Which lines should I be checking? Sorry I'm not familiar with the entire fuel system with the FCC and all
    There are only 2 vacuum lines from the intake manifold to the MAP sensor and to the fuel pressure regulator.
    A bad fuel injector could be the problem you can test these without removing them.
    Use a fuel pressure tester to monitor pressure and turn ignition on
    Pressure builds up to 36psi or so
    The pressure should stay above 30 for at least a few minutes or you have a leaky injector.
    Now you need a external 12v source and connect it to the first injector for 1 sec.
    The pressure will drop a certain amount.
    The drop should be the same for all injectors.
    Or run the engine and use a stethoscope to listen to each injector if on is not kicking it's bad.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Leave a comment:
  • Aaren22
    replied
    I have this same boat and had the same problem. I threw a bunch of parts at it and it ended up being a clogged fuel injector
    Leave a comment:
  • Danny Roberts
    replied
    Originally posted by Peter6000 View Post
    I would start by checking fuel pressure
    If OK check all sensors and idle air bypass valve and clean throttle body while you on it.
    Check the vacuum lines.
    Leave a comment:
  • Peter6000
    replied
    2001 GT40 is "surging" after running at high rpms for no longer than 5 minutes. The more the rpms the sooner the problem appears. It will run all day fine at a lower rpms (say below 3000). So far replaced relays, fuel filter, plugs cap & rotor. Any ideas? No engine lights, all fluids are fine. Next step i can think of is anti siphon valve on tank, fuel lines, and then high pressure fuel pump. Its almost like the engine is "starving" for fuel at a higher rpms or under load.
    Leave a comment:
  • HELP GT40 2001 SAN surging after running high RPMs
