I have 1999 Ski Nautique stopped running after 2 min found water on the spark plugs, I drained the high pressure fuel pump almost clear water came out.
My tank was quite empty so I drained it completely with the low pressure fuel pump about 4 G of fuel water mix.
Is there a way to completely drain the tank without taking it out?
I'm pretty sure there is some bad fuel left in the tank.
