Hey folks, just bought this boat (~~3 weeks ago), we've put about 18 hours on it so far (198 total now). It's been great but one issue we have experienced, not consistently which is frustrating, is when we stop the motor after running for awhile to just jump in the lake and swim around we can't get it to start up. Again, its inconsistent, sometimes it fires up no problem, others we literally have to just keep trying then all of a sudden it'll just fire up.
More simply we are in Run Mode using the boat, we will stop to swim and I shut down the motor by pushing the "Stop" button and putting the boat into Unlock mode. If we want to get going again, I should just be able to push the "Start" button to move it back into Run Mode (yes indicator light turns on) and then again to start the boat. Sometimes it fires, sometimes it doesn't. Only once did I start to get too worried as we were drifting towards someones dock. Thankfully it fired up and I was able to pull away.
Anyhow, not sure if its me or if its an ignition issue I should have looked at....
Appreciate the help for this newbie.
Jeff
Jeff
