Water leaking ?
  • River Junkie
    • Apr 2020
    • 5
    • TEXAS
    • looking for 95-00 nautique
    Water leaking ?
    Went to put new speedo pickup on removed screw and water poured out how would water get up on that side ? Do I need to add drain plug ?
  • River Junkie
    • Apr 2020
    • 5
    • TEXAS
    More info it is on 92 snob excel it only has one drain plug in center currently
    • River Junkie
      • Apr 2020
      • 5
      • TEXAS
      finally got pic uploaded from what i understand there is only foam outside of the stringers how would i be getting water in there
      • bturner
        • Jun 2019
        • 1790
        • MI
        • 2016 200 Sport Nautique
        I'll let someone with more experience chime in but my first take on this would not be good. If my understanding is correct the 92 still had wood stringers and 93 was the first year for no wood but hopefully for your sake I'm wrong. Water will find a way to get into anything and if I understand what you're saying correctly water has infiltrated into the sub floor stringer system. I've seen this in a couple older boats I worked on and in those cases it was a mess to repair on those boats as the water had rotted a portion of the floor and several areas of the stringer system. We ended up scraping out all the foam and paying a local shop to do the stringers and the floor.
        Hopefully I'm completely wrong about your boat.
