Boat was stored outside over the winter under a tarp but there was evidence of a slight amount of seepage
A Battery tender was running on a timer to run 4 hours a week - battery was not disconnected.
Uncovered boat - battery dead. Disconnected cables charged and tested battery with load tester. Good
Attached all cables( to correct posts) and tried to enter op. code on key pad. No clicks, no pilot lights, no gauges,no bilge blower, no horn, no power to either of the 12V recpt.
Power is flowing through the 60A overload on the back of the motor.
There is power to the gateway/breaker box under the dash
There is power supplying both key pads - 12V through the red/black wires and 2.5V on each of the other two wires
The emergency disconnect tether switch appears to be good
I have no battery disconnect switch installed
Mice were in the boat over the winter - plenty of droppings but none of the wiring inside the dash appears to be chewed
The gateway really doesn't look like anything I could service, although none of the overloads appear to be tripped. It's clean inside
Can anyone give me an idea where to start/continue to check ?
Ken
Ken
