Announcement
No announcement yet.
Oil pressure for a ZR6
  • TNRIDER
    replied
    So I did my 1st oil change to the new dexos 5-30 and I'm noticing a little lower oil pressure. Would that be normal? 27-30 at idle and 42-50 pulling and cruising.
    Leave a comment:
    replied
    You really should run PCM's recommended oil, which is not 15W-40 for that engine.
    https://www.planetnautique.com/vb5/f...specifications
    Leave a comment:
  • Nautique Fan
    replied
    My manual for a 2007 says 25-80 psi at 2,000 RPM. 10 psi minimum at idle.
    Leave a comment:
  • Jbousman88
    started a topic Oil pressure for a ZR6
    Normal oil pressure for a ZR6 running the shell rotella 15w40?
