I've been working on restoration of this 2000 SAN python 502 this spring and finally had it out on the lake last week.. Made it great for 4 days and then on the morning of the 5th day, it started and then died and haven't been able to get it to fire since. Here is what I've checked..
1. With the start button pressed I can hear the fuel pump wind up.
2. Fuel pressure is 42 psi at the fuel control cell and 43 psi at the injector rail
3. Compression is good
4. Tank has fuel..
5. Checked spark and it's also good.
Any thoughts? I've gotten conflicting info on the fuel pressure.. I've found that 55 psi is normal and also found 40 psi is normal? Could it be the fuel pump?
Thank you in advance!!
Marc
