hi - i'm posting because i have a problem and the local marinas say they cannot look at the boat for 2 months!?! it is a 2010 Super Air Nautique TE 210. it was having a problem starting last year. shop said it "started fine" when they winterized it and i guess did not do much more to look for the problem, despite me asking them to fix it,
now it is doing it again. last summer it seemed to be ok if i started it weekly. but then it would run roughly until we used it for a bit. this year we did not run it for the first month after we put it in. then when we tried last week, i thought it would never start. just cranked and cranked. had to press the button on the throttle to disengage transmission, and pushed the throttle all way forward and it finally caught. now it is a week later - just went out and was able to start it. so similar to last summer. and again it hunts and does not idle well until i run it around at high speed for a bit. in fact, today it died several times sitting at the dock until i took it out. you can see in the videos the rough idle at first, then the smoother one after use......
also have something new this year, which is a rattle when i engage transmission at slow speed. this noise also went away after i ran it around for 10 min.
i'd pay someone to fix it if i could find someone to pay. if i wait 2 months, i might as well just have them winterize it and put it away, since they will take weeks to fix anyway.
so hoping someone has some advice..... sorry if i am a bit clueless!
https://www.dropbox.com/s/0lfyqqlrob...03.13.mov?dl=0
https://www.dropbox.com/s/80u4jdzzfn...15.31.mov?dl=0
