Greetings,
I've been getting my '94 Sport Nautique ready for summer and had changed the oil, replaced the impeller, and put all the plugs back in. I fired it up with a fake a lake, and noticed that there wasn't any water coming out of the exhaust. I quickly shut it down, fearing that I had messed up the impeller installation process. I took the impeller back apart and it had been getting water and was still in good shape. I started it up again, and still no water out of the exhaust. I again only let it run for about a minute, maybe two at the most. Once I was able to get a second pair of eyes on the engine compartment, we noticed water coming out of the engine block. Two of the freeze plugs had popped out. We winterized it, but probably not as well as we should have. With all that said, I'm having trouble figuring out how to tap in the new plugs. I bought two new brass plugs. They aren't as shallow as the ones that popped out, but I don't think that will be too much of an issue? The angle of the engine and the area I have to work with have me scratching my head. Ive read in other posts that a socket with an extension can work. Any other ideas? One of the other issues is that the one plug is directly behind the right forward motor mount, and is even harder to get to. Other questions related to this: There seems to be a debate on whether or not to put any kind of sealant on the plugs before installing them. Lastly, is there anything else I should be concerned about after having run the engine a few times with the plugs out? I appreciate all and any help. Thank You!
